Выход новых обновлений софта программаторов TNM 2000 TNM5000 - Страница 7 - Форум
neutecДата: Понедельник, 18.06.2018, 18:16 | Сообщение # 91
Mr. Danila, thank you very much for the update, a cordial greeting, thank you ...
Danila_ivaДата: Воскресенье, 15.07.2018, 12:28 | Сообщение # 92
http://www.tnmelectronics.com/downloads/Upgrade1023.exe
по изменениям пока нет информации
AndrnetДата: Воскресенье, 15.07.2018, 12:33 | Сообщение # 93
Так вроде в текстовом файле есть
Version 10.23-July 15 2018:
Infineon Tricore TC1724 Flash / Data-Flash Programming is Added to model5000.
NPCE388 / uPD70F3623 / uPD70F3624 / R5F61797 are added to model5000.
RL78/D1A EEPROM read & write added to Model5000: R5F10CGB / R5F10CGC / R5F10CGD / R5F10DGC / R5F10DGD / R5F10DGE / R5F10CLD / R5F10DLE /R5F10DPJ / R5F10DPK / R5F10DPL / R5F10DPE / R5F10DPF / R5F10DPG / R5F10DLD / R5F10TPJ / R5F10DMJ / R5F10DME / R5F10DMF / R5F10DMD / R5F10DMG / R5F10DSJ / R5F10DSK / R5F10DSL
http://www.tnmelectronics.com/downloads/TNM-CAR.pdf file is updateR5F10DLEd for newely Added Car Circuits.
http://www.tnmelectronics.com/downloads/ITE-keymapConfigTNM.rar file is updated for new ITE motherboards.
http://www.tnmelectronics.com/downloads/ENE-keymapConfigTNM.rar file is updated for new ENE motherboards.
Nand Programmer Software Version Version 6.7-Jun 18 2018:
H27U8G8T2B / 29F2G16AAD / 29F2G16ABD / K9LBG08U0M / TC58NVG5D2FTA00 are Added.
MT29F2G16AAB Bug is fixed:
Добавлено (05.08.2018, 22:38)
Новое обновление
http://www.tnmelectronics.com/downloads/Upgrade1024.exe
Version 10.24-August 5 2018:
Samsung BGA63 ONENAND KFG1GN6W2D / KFG1G16U2D / KFG1G16Q2C / KFG1216Q2A / KFG1216U2A are added to model5000.
Renesas R8C/26: R5F21262 / R5F21264 / R5F21265 / R5F21266
Renesas R8C/27: R5F21272 / R5F21274 / R5F21275 / R5F21276 are added to model5000.
Infineon Tricore TC1728 Flash / Data-Flash Programming is added to model5000.
PuyaSemiconductor Serial Flashes 25QxxL / 25QxxH Series are added to model5000.
AdminДата: Понедельник, 06.08.2018, 09:30 | Сообщение # 94
In new version of 10.24 we add onenand BGA 63 chips KFG1GN6W2D / KFG1G16U2D / KFG1G16Q2C
Until we produce adaptor for this , users can use
RT-BGA63-01 V2.0 adaptor, it is compatible with our programmer.
В новой версии 10.24 мы добавим OneNAND BGA 63 микросхемы KFG1GN6W2D / KFG1G16U2D / KFG1G16Q2C
Пока мы не производим адаптер для этого, пользователи могут использовать
RT-BGA63-01 V2.0 адаптер, он совместим с нашим программатором.
http://www.willem-ua.com/shop....10-5x13
http://www.willem-ua.com/shop....er-11x9
http://www.willem-ua.com/shop....13x10-5
oomarcelOOДата: Вторник, 14.08.2018, 19:57 | Сообщение # 95
AdminДата: Вторник, 14.08.2018, 23:22 | Сообщение # 96
Version 10.27-August 14 2018:
MC9S12XA128 / MC9S12XB128 / MC9S12XD128 / MC9S12XDT256 / MC9S12XDQ256 / MC9S12XDT384 / MC9S12XA512 / MC9S12XDG512 /MC9S12XDP512 / MC9S12XDT512 are added to model5000.
W25Q128JV / IS25LQ025B / IS25LQ010B / IS25LQ020B / IS25LQ040B / IS25LQ512B are added to model5000/2000.
AndrnetДата: Вторник, 09.10.2018, 18:03 | Сообщение # 97
Народ, вышло обновление новое 10.31, правда мало что добавили.
ADESTO Data flash AT25PE16 / AT25PE80 / AT25PE40 / AT25PE20 / AT45DB021E / AT45DB041E / AT45DB081E / AT45DB161E / AT45DQ161 / AT45DB321E / AT45DQ321 / AT45DB641E are added to model5000.
AM29BL162C SSOP56 / DA28F640J5 SSOP56 are added to model5000.
Сообщение отредактировал Andrnet - Вторник, 09.10.2018, 18:03
KodovДата: Среда, 10.10.2018, 12:11 | Сообщение # 98
Да попутно вышла и Version 6.8 - OCT 10, 2018
AdminДата: Понедельник, 29.10.2018, 09:38 | Сообщение # 99
oomarcelOOДата: Суббота, 10.11.2018, 19:56 | Сообщение # 100
Сообщение отредактировал oomarcelOO - Суббота, 10.11.2018, 20:18
AndrnetДата: Среда, 12.12.2018, 18:08 | Сообщение # 101
Новый софт
http://www.tnmelectronics.com/downloads/Upgrade1034.exe
Version 10.34-Dec 12 2018:
uPD70F3xxx Series 3-Wire Mode programming is added to model5000.
NEC V850 MCUs: uPD70F3735 / uPD70F3736 / uPD70F3737 / uPD70F3738 / uPD70F3627 / uPD70F3628 / uPD70F3629 / uPD70F3630 / uPD70F3402 / uPD70F3403 /
uPD70F3231 / uPD70F3232 / uPD70F3233 / uPD70F3234 / uPD70F3235 / uPD70F3236 / uPD70F3237 / uPD70F3238 / uPD70F3239 / uPD70F3416 / uPD70F3417 / uPD70F3451 / uPD70F3452/ uPD70F3453 / uPD70F3454
uPD70F3464 / uPD70F3465 / uPD70F3466 / uPD70F3469 / uPD70F3470 / uPD70F3471 / uPD70F3472 /uPD70F3505 / uPD70F3506 / uPD70F3507 / uPD70F3508 / uPD70F3509 /
uPD70F3610GB / uPD70F3611GB / uPD70F3612GB / uPD70F3613GB / uPD70F3614GB / uPD70F3615GK / uPD70F3616GK / uPD70F3617GK / uPD70F3618GK / uPD70F3619GK /
uPD70F3620GK / uPD70F3621GK / uPD70F3622GK /uPD70F3625 / uPD70F3626 / uPD70F3636 / uPD70F3637 / uPD70F3638 / uPD70F3700 / uPD70F3701 / uPD70F3702 /
uPD70F3703 / uPD70F3704 / uPD70F3706 / uPD70F3707 / uPD70F3709 / uPD70F3710 / uPD70F3711 / uPD70F3712 / uPD70F3720 / uPD70F3721 / uPD70F3722 / uPD70F3723 /
uPD70F3724 / uPD70F3778 / uPD70F3779 / uPD70F3780 / uPD70F3781 / uPD70F3782 / uPD70F3783 / uPD70F3826 / uPD70F3827 / uPD70F3828 / uPD70F3829 / uPD70F3830 / uPD70F3831 / uPD70F3832 / uPD70F3833
uPD70F3834 / uPD70F3835 / uPD70F3836 / uPD70F3837 are added to model5000.
FreeScale MC9S12XS128 / MC9S12XS256 are added to model5000.
W25Q40EW / XM25QH256B / XM25QU256B / XM25QH128 / XM25QH40 / XM25QH20 are added to model5000.
MC9S12XHZxxx Series file format bug from previous versions removed.
PIC ID error from ver-10.32 is Fixed.
groffДата: Среда, 09.01.2019, 11:46 | Сообщение # 102
Новый софт
http://www.tnmelectronics.com/downloads/Upgrade1035.exe
Version 10.35-JAN 8 2019:
in Device List, "ECU" group is added to 5000 Device list.
Bosch EDC16C39 / Bosch Me9.7 ( mercedes benz E350 ) / SIM2K-240-TGDI are added to ECU group in Model 5000.
Motorola MPC564 internal Flash, External Flash and External EEProm are Added to Model 5000.
EMMC Ext-CSD Edit & verify is Added to 5000.
AT90S4414 / GD25Q40C / GD25Q20C / XM25QH128 Otp / XM25QU64 / XM25QU64 OTP are added to Model5000 / Model2000.
INFINEON Tricore TC1738 / TC1767 / TC1797 are Added to Model5000.
uPD78F08xx Specific sector Erase /programming is added to Config of the Chip.
SAK-XC164CS-32F is Added to Model 5000.
ATmega162 TQFP 44 pin (ISP on ZIF) is Added to Model 5000.
oomarcelOOДата: Вторник, 22.01.2019, 16:40 | Сообщение # 103
обновление 10.36
http://www.tnmelectronics.com/UpdateProgrammer.html
http://www.tnmelectronics.com/downloads/Upgrade1036.exe
Version 10.36-JAN 21 2019:
Texas instrument following MSP430F Microcontrollers through Jtag is Added to Model 5000:
MSP430F1101A / MSP430F1111A / MSP430F1121A / MSP430F1122 / MSP430F1132 / MSP430F1222 / MSP430F1232 / MSP430F2101 / MSP430F2111 /
MSP430F2112 / MSP430F2121 / MSP430F2122 / MSP430F2131 / MSP430F2132 / MSP430F2232 / MSP430F2234 / MSP430F2252 / MSP430F2254 /
MSP430F2272 / MSP430F2274 / MSP430G2153 / MSP430G2213 / MSP430G2230 / MSP430G2253 / MSP430G2313 / MSP430G2353 / MSP430G2413 /
MSP430G2444 / MSP430G2453 / MSP430G2513 / MSP430G2544 / MSP430G2553 / MSP430G2744 / MSP430G2755 / MSP430G2855 / MSP430G2955
Добавлено (06.02.2019, 18:14)
http://www.tnmelectronics.com/downloads/Upgrade1037.exe
Добавлено (06.02.2019, 18:21)
Version 10.37-Feb 6 2019:
Infineon XC2000 Series through JTAG is Added to Model 5000:
XC2336A-56F / XC2336A-72F / XC2361A-56F / XC2361A-72F / XC2363A-56F / XC2363A-72F / XC2364A-56F / XC2364A-72F / XC2364A-104 / XC2365A-56F
XC2365A-72F / XC2365A-104 / XC2336A-56F / XC2336A-72F / XC2361B-24F / XC2361B-40F / XC2363B-24F / XC2363B-40F / XC2364B-24F / XC2364B-40F
XC2365B-24F / XC2365B-40F
SANTAFE2015-XC2361A added to ECU\AirBag
AndrnetДата: Воскресенье, 10.02.2019, 11:00 | Сообщение # 104
обновление 10.37
Добавлено (10.03.2019, 10:03)
Вышла новая версия.
http://www.tnmelectronics.com/downloads/Upgrade1039.exe
Version 10.39-March 10 2019:
MX25L12835F Fuse Bits are Modified. S25FL127S Erase Bug is removed.
MX25L6436F / MX25L6436F-OTP / S25FL127S-Security / MT25QL128ABA / MT25QL128ABA-Security / MT25QL256ABA / MT25QL256ABA-Security
MT25QL512ABA / MT25QL512ABA-Security /MT25QU128ABA(SO8) / MT25QU128ABA-Security / MT25QU256ABA / MT25QU256ABA-Security / MT25QU512ABA / MT25QU512ABA-Security
N25Q00AA11 / N25Q00AA11-Security / N25Q00AA13 / N25Q00AA13-Security / N25Q016A11E / N25Q016A11E-Security are added to Model5000 / Model2000.
EMMC Low density Support is added. EMMC boot in EXT_CSD corrected. Improvment for EMMC detect / read and Write.
upD78F0881A / upD78F0882A / upD78F0883A / upD78F0884A / upD78F0885A / upD78F0886A / upD78F0894A / upD78F0895A
ОјPD78F0887A / uD78F0888A / uD78F0889A / uD78F0890A / uD78F0891A / uD78F0892A / uD78F0893A /uD78F0894A / uD78F0895A are added to Model5000.
Сообщение отредактировал Andrnet - Воскресенье, 10.02.2019, 11:00
AdminДата: Пятница, 15.03.2019, 12:19 | Сообщение # 105
Обновление Upgrade1039.rar , крайне рекомендовано для работы с EMMC
