29F2G08ABAEA The copy is not working. - Форум
musgokceДата: Суббота, 18.03.2017, 13:46 | Сообщение # 1
I am running nand flash, I am writing another nand flash, the device is not turning on. I am experimenting with a few boards that have a solid flash of data.
I did not do reading and writing with tnm5000, I did not do it with rt809fpeb-1.
Flash: 29F2G08ABAEA
Led tv model: 60le652 sharp
Why can it arise?
Прикрепления: 9099537.jpg (357.5 Kb)
onkyoДата: Воскресенье, 19.03.2017, 09:15 | Сообщение # 2
Please describe in detail the defect.
Where did you get the firmware?
Is there a bad block in the chip, and how much?
I'll look at the firmware.
musgokceДата: Вторник, 23.05.2017, 16:53 | Сообщение # 3
Hello, sharp 39le752 or 50le752 (le652). I am reading the integrated flash file running, I am writing the new flash integration, it is not opening. I'm plugging in the flash card of another card. I have not read 3 or 4 running flashes, it is not. Could it be protection in the flash? There is no corrupt sector in flash integrated.
I integrate the working flash file I read. I uploaded 2 files to flash integration, it does not work. Could you help?
https://drive.google.com/file/d/0B2a_e2fCC9HrajlncEJpeWVWZmc/view
