Notification in error programmed program ( RT 809 H ) - Форум
ELSHAGRA2009Дата: Суббота, 18.03.2017, 02:59 | Сообщение # 1
Good morning
Company, to you Greetings: IFIX ....... Respected.
Notification in error programmed program (RT 809 H).
There are a mistake in reading the type (CSI) Eprom I could not read this type because I believe that feed this type of (CSI) Eprom selection of the system of feeding 5 volt and not 3.3 volt so the program must be adjusted to the 5 volt system to read the type of this
Errors:
1 - There is no automatic selection of the quality (CSI) Eprom of this
2 - Selection. (Select) I can not move and reach the 5 volt selection.
And the opinion of the programmer (RT 809 H) it is one of the best words located inside EgyptAnd the engineer: Ahmed Hamdan. We are responsible and responsible and are considered one of the best agents in EgyptFor this programmer ( RT 809 H).
Добавлено (18.03.2017, 02:59)
http://www.ww.ifix.net.cn/thread-61560-1-1.html
Прикрепления: 2191028.jpg (4.6 Kb) · 0533323.png (148.4 Kb)
