[HELP] first time with stanson s29al016d70tf10
phantom | Дата: Понедельник, 07.01.2013, 18:42 | Сообщение # 1 |
| hi to all, i would like to reprogram a
"stanson s29al016d70tf10". this is the first time in my life that i will program an eprom! so i would like to have your help! this is my programmer with some adapters:
http://img831.imageshack.us/img831/3046/83514118.jpg
also i don't understand how to connect the adapter to the programmer!!! could you help me??
sorry for my bad english, i'm italian and i speak only english a little bit!
terehov_i | Дата: Вторник, 08.01.2013, 13:09 | Сообщение # 2 |
Рекламатор
Admin | Дата: Вторник, 08.01.2013, 13:19 | Сообщение # 3 |
| on your photos, not the correct adapter.
need this one adapter TSOP48 8/16 bit.
phantom | Дата: Вторник, 08.01.2013, 16:59 | Сообщение # 4 |
| could you explain me the difference between TSOP48 8/16 bit and TSOP48 8bit?
Shabbat | Дата: Вторник, 08.01.2013, 17:03 | Сообщение # 5 |
| Цитата (phantom) could you explain me the difference between TSOP48 8/16 bit and TSOP48 8bit?
"TSOP48 8bit?" what kind of adapter? give photos
sometimes they are called in different ways, but it's the same thing.
not to be confused with pure 16-bit two different things.
"TSOP48 8bit?" che tipo di adattatore? le foto dei
a volte sono chiamati in modi diversi, ma è la stessa cosa.
da non confondere con la pura a 16 bit due cose diverse.
Сообщение отредактировал Shabbat - Вторник, 08.01.2013, 17:11 |
phantom | Дата: Вторник, 08.01.2013, 17:22 | Сообщение # 6 |
Shabbat | Дата: Вторник, 08.01.2013, 17:29 | Сообщение # 7 |
| What's the difference between these adapters to link to, ask the manufacturer of these adpterov. namely
You asked what you need an adapter for programming of the chip. asked how to do this with your adapters. you answered.
for your chips need an adapter 8-16 bits.
phantom | Дата: Вторник, 08.01.2013, 17:32 | Сообщение # 8 |
| perfect! than the problem in s how to connect this adaptor into the programmer! could you help me?
Shabbat | Дата: Вторник, 08.01.2013, 17:35 | Сообщение # 9 |
| Select is selected the desired use in software. expose dip12 switch adpter put the programmer in a large green connector. soedenyaete train came with the adapter to the PG plugs near the red LED.
Working.
phantom | Дата: Вторник, 08.01.2013, 20:05 | Сообщение # 10 |
| sorry i don't understand your english: maybe you can write in russian and i will try to translate in english with google translate??
terehov_i | Дата: Вторник, 08.01.2013, 23:12 | Сообщение # 11 |
Рекламатор
phantom | Дата: Вторник, 15.01.2013, 18:11 | Сообщение # 12 |
| what's your problem? shabbat is helping meДобавлено (15.01.2013, 17:11) --------------------------------------------- adapter 8/16 arrived. i've mounted all like this: what do you think?
http://imageshack.us/photo/my-images/717/84751519.jpg
it's ok how i've mounted them? is it ok that i connect the gray cable
Shabbat | Дата: Среда, 16.01.2013, 20:17 | Сообщение # 13 |
| phantom, переверните шлейф который вы подключили к программатору. у вас на адаптере разьем для шлейфа , контакт 1 это Clock ( на шлейфу красная полоска) На программаторе она должна быть вверху. А у вас в низу- неправильно.
phantom , ruotare il ciclo che è stato collegato al programmatore. si ha il connettore dell'adattatore per cavi, il pin 1 è l'orologio (barra rossa sul treno) Il programmatore dovrebbe essere in cima. E tu hai in basso a destra.
phantom , turn the loop that you have connected to the programmer. you have the adapter connector for cables, pin 1 is the Clock (red bar on the train) The programmer it should be at the top. And you have the bottom-right.
