tnm5000 help K9F4G08U0D - Форум
rtnДата: Среда, 13.06.2018, 20:13 | Сообщение # 1
hi all
problem writing and deleting
Nand K9F4G08U0D
Chip 0 ID:9510dcec
Chip 1 ID:ffffffff
Chip 2 ID:ffffffff
Chip 3 ID:ffffffff
Deselect ReadBack:ffffffff
ONFI string: ìÜ•
Model: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Page Bytes + Spare : -1 + 65535 = 65534
Number of Pages in Block : -1
Number of Blocks in chip : -1
Number of Chips : 255
Column Addresss Cycles : 15 - Row Addresss Cycles : 15
Bytes per Partial Page : -1
Bytes per Partial Page : 65535
Start Erasing...
x
Erase Error in total 1 Blocks.
Start Programming With Verify 540672 Kbytes from File: C:\Users\RTN
....x
Help me
thank you
groffДата: Четверг, 14.06.2018, 10:48 | Сообщение # 2
It's normal, you have 1 bad block. It can't be erased or programmed. See Help in app. X mean bad block.
rtnДата: Четверг, 14.06.2018, 11:32 | Сообщение # 3
Hi, thanks for answering me
but, I do not know how to solve
could you help me please
Прикрепления: 9945446.jpg (300.4 Kb)
groffДата: Четверг, 14.06.2018, 14:07 | Сообщение # 4
First erase, than programm and try it in device. If bad block doesn't contain important data it will be OK. It's must work with that 1 bad block.
rtnДата: Четверг, 14.06.2018, 17:02 | Сообщение # 5
Clear Flash
when I write Flash
.... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x .... x
Program verification error in total 3 blocks.
maybe you have to set it in DEVICEDEFN.TXT
you know how I can do it
thank you
groffДата: Четверг, 14.06.2018, 17:39 | Сообщение # 6
I don't know. You can try with lower frequency in config.
Clean all pins on adapter and chip with alcohol.
Сообщение отредактировал groff - Четверг, 14.06.2018, 17:48
rtnДата: Четверг, 14.06.2018, 17:52 | Сообщение # 7
once the problem solved me
Danila_iva
do you know how to contact him?
groffДата: Четверг, 14.06.2018, 18:13 | Сообщение # 8
He's on the forum here, too.
I had the similar screen like you with different chip but it work in my device.
Сообщение отредактировал groff - Четверг, 14.06.2018, 18:16
rtnДата: Четверг, 14.06.2018, 18:22 | Сообщение # 9
how did you solve it?
groffДата: Четверг, 14.06.2018, 18:25 | Сообщение # 10
I didn't do anything, programmed like on screen at you, and it work in device.
rtnДата: Четверг, 14.06.2018, 18:29 | Сообщение # 11
so if I program the Nand Flash
then does it work?
